i just reformatted, and when i dodi know have the comp asking which os i wanna start, know ive heard a way on how to remove this before, i should have 2 of the same file in my system file, what is the name of the file so i can go and remove it..thanks guys
Results 1 to 9 of 9
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Don't know about the file thing, but you can right click My Computer > Properties > Advanced > Start up and Recovery and uncheck the display list of operating systems.
naw man, theres a .dll file that im talkign about, i know some one knows about it, ive seen the question in hrere before
It's in the C:\ Folder. It's called "boot"
Check and make sure the files aren't hidden and then you can edit it here's an example
[boot loader]
timeout=3
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional (bootscreen)" /fastdetect /KERNEL=kernel1.exe
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect -
You can modify the boot.ini file and remove the reference to the OS you DON'T want to boot. It's read-only so make sure you uncheck read only before you save it and re-check read only after you save it. Another option is to set your timeout to 0, so it goes right into Window$, no waiting.
Nothing can stop me now, 'cause I don't care anymore. -
make it easier for me guys, i wanna do this without having to reformat again
goto Run...
type msconfig then enter
System Utility will appear
goto boot.ini tab
you can edit anything from therehacking the Net using typewriter :D -
that fixed everything, thanks man
Booting from PCI IDE
By AuroEdge in forum ComputerReplies: 53Last Post: 14th Aug 2014, 11:09 -
I have a blank screen when booting
By edong in forum ComputerReplies: 4Last Post: 17th May 2010, 00:19 -
booting problems
By romanstopme in forum ComputerReplies: 11Last Post: 8th Sep 2009, 14:58 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 13:23 -
Booting issue ... PC problem!!
By Lucifers_Ghost in forum ComputerReplies: 35Last Post: 14th Jan 2008, 18:17
