Has anybody had any experience with this card.
Can it be used for capturing and is the quality any
good. I have had it for a couple of years and
can not get much info on it. It works fine
as a TV tuner
If it does work where can I get the latest
drivers.
I have the FlyVeiw98. It works fine. Ive done little capturing with it, but it seemed to go fine.
Latest drivers are on their webstie. I cant remember it off hand, but do a search. I like it since it was so cheap. 158 dollars in New Zealand. It also has the FM radio bit as well.
A working XP SP3 driver for Flyvideo 98 - Please help
By danroberto in forum Capturing and VCRReplies: 5Last Post: 28th Aug 2010, 14:10
