I bought a PAL VCR and I'm having bad luck with the results.
I'm taking the VCR's output into the CT2 (which supposedly automatically detects whether it's PAL or NTSC).....set the CT2 output switch to NTSC and then going to the input on my Panasonic DMR-E50.
I'm monitoring on an NTSC TV connected to the DMR-E50.
It's almost like the CT2 isn't doing anything as I have a very distorted picture on my monitor when trying to record a PAL tape.
Has anyone used this CT2 for PAL to NTSC conversion?
What do you think is going on here?
Are there maybe some unique protection techniques that are unique to PAL that the CT2 can't handle?
THANKS for any help!
Read pg 5 bottom section n what it will NOT DO!
It can conver color encoding but not FRAME RATE1 YOU have to have a 50/60hz tv or monitor that can do BOTH in order to view.
The unit is for making stable copies of vcr or dvd source on vcr or dvd. I just bought one today and it seems to work great for its intended use, based on just a quick test.
=JD=
JD tinkerer pushin' 60,
A real Life Enemy of the State, see Fed case #01-40080, Detroit.
Computers, Electronics, vintage Audio, Photography Film/digital/3D, N-Scale RR, ,
AKA the "Infamouse Joe Walker" ,Join the Navy & see (1/2) the world. -
So it's really not (completely) converting PAL to NTSC?
Everything but the frame rate?
What are my options?.......are there any US TV's that will allow 50/60 hz viewing or do I have to get a PAL TV? (I'm using a litlle 9" color portable to monitor right now).
Is there a frame rate "converter" that will give me a final disc on DVD
that is fully compatible with an NTSC TV?
Thanks for your response.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
