I backup my movies using dvdxcopy express RF. And if it is a episodic dvd I use dvd decrypter and dvd shrink, then I use RF. I noticed that when I am at work watching them on a 52 inch tv, the audio starts to trail away from the video. You can pause the movie and then play the movie and the audio is corrected. Sometimes artifact will appear and ruin the movie but when played on a smaller tv everything is fine. Any burning suggestions or fixes? Thanks
You watch DVD's at work? I am glad you don't work for me!
There is NO reason that sync would be off on a 52 inch screen, and not on a smaller TV. I have a 52 inch TV, and sync is ALWAYS the same on it as it is on the smaller sets here.
Only things I can think of is that you can see the sync problem better on the larger set, or that the DVD player at work is somehow causing sync problems. I have seen that before on VCD's where they would play fine on one player, but be out of sync on another.
Dump DVD Xcopy. It's a poor program, and they are no longer in business. -
You guys are funny. I work for Horry County Fire Rescue in south carolina. 24 hr shifts are long. You may be right about the player. What do you guys use to burn? I have Nero but only use it to backup copies.
I use Nero. For
DVD backups
, I use either DVD Decrypter, DVDShrink or DVD Rebuilder. You can configure them to use the Nero engine to burn DVDs.
Isn't there a Horry County Fire Rescue company near the Walmart's at Myrtle Beach? -
Yes there is....on 21rst ave north there is medic 30 station and on forestbrook road there is engine 4 station. Both are about 2 miles or less from MB. Myrtle Beach has there own fire department. Thanks for all the help guys I think I'll start trying NERO.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
