I have a .avi file in DivX form and I need to get it to play in my DreamCast (using Gyplay or a similar program). I tried it once and Gyplay came up with "Error2". Is there a place I can read Step-By-Step instructions? thanks!
I seem to recall this page had some good info.
Bear in mind that you cannot play divx's on the DC. You will have to convert the avi to an mpeg(1) or dat to play it. You'll most likely need 2 cds for the converted divx/avi
...when you convert the file - you should set the bitrate a bit lower than usual and th DC will play it much more smoothly than with a normal vcd.
I'd say the lower quality is made up for with the better framerate.
[/nostalgia] ahh..the days of vcd on Dc
[/nostalgia]
What Page?? I know about the mpg 1 thing I just dont know how to do it correctly
Reading AVI/MPG/DIVX files from a BD-R in PS3 or other
By harryman in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Dec 2011, 09:40 -
Dreamcast video
By Avatar in forum Newbie / General discussionsReplies: 24Last Post: 10th Sep 2009, 19:38 -
Unlikely console revival - Dreamcast ??
By Noahtuck in forum Off topicReplies: 9Last Post: 8th May 2009, 19:44 -
Is the Playstation 3 destined to go the way of the Sega Dreamcast?
By yoda313 in forum PollsReplies: 32Last Post: 21st Jan 2009, 17:18 -
Encoding Dreamcast onto iMac for fullscreen viewing
By karas in forum MacReplies: 5Last Post: 13th Nov 2007, 09:00
