I mean we have bombs that can blow up a country
we have cellular phones
wireless internet
but we can't convert PAL to NTSC without jitters???![]()
I have a PIONEER DV-270 plays everything...why isn't there a Hack for it so I can play PAL...
someone...anyone....!![]()
Results 1 to 19 of 19
Have you ever taken your cell phone to another country? Trust me, it dies, unless you're on the same type of system. Most are not universal.
Sure, USA and Russia both have huge bombs! Think they work the same? Not on your life.
You can easily convert PAL to NTSC, and NTSC to PAL, and SECAM to PAL, and PAL to SECAM, and NTSC to SECAM, SECAM to NTSC ... if you buy the proper equipment.Want my help? Ask here! (not via PM!)
I'm just frustrated with it all.
So I need professional equipment just to watch "A fish called Wanda" at home? That just doesn't seem right.
And I can take my phone out the country and put a new chip in it and it works like a charm -
Originally Posted by concrete
That's because they want you to by the dvd in the region it's intended for. And your out of luck if it's not released there yet. BECAUSE it takes so much work to convert it's easier to hope for the release in the correct format. It does suck but they control it.
It's not that difficult. And your conversion is an easy one. Your source is film. If that frustrates you, you should definately not attempt to do PAL video to NTSC video or vice-versa.
Darryl -
My $100 PIONEER DV-363 player makes PAL to NTSC quite well.....
Zetti -
My $40 Cyberhome plays PAL pretty well. My $250 LiteOn DVD recorder (now about $150) plays PAL perfectly. These are DVDs mind you.
What you did is sort of like buying a British car. Your steering wheel is on the wrong side of the car. It was not meant for you. But you bought it anyway, so now you've got to figure out how to make it work.Want my help? Ask here! (not via PM!)
As others have said, there are methods for converting PAL to NTSC, but whichever method and tools you choose, they all require some learning and effort. If you are not willing to expend the required efoort, go down to your local DVD player retailer and buy a player that will do the conversion for you, but make sure it is (or can be made) region free too. Some effort required there too I am afraid.
How about some one-upsmanship (one-downsmanship)?: My $35 Yamakawa DVD-218 plays PAL DVDs on my NTSC television pretty well!
Originally Posted by bugster
I had no problem making a PAL 25i video into an NTSC 30i video. It looks great to me. I cannot tell the difference unless I compare the two frame for frame. Video is detailed and motion is fluid and jitter free. The audio synchs up perfectly. And converting interlaced PAL is supposed to harder than film. The only thing that should even come close to challenging is synching the audio. But it is easy as well. Read the guides.
Darryl -
There is a new tool in the new tools section that supposedly will take a pal DVD straight to a NTSC DVD.
Someone let me know if it works or not? heh heh. -
tmpg enc/procoder express will do it in time
cyberlink power producer will do it in shorter time
You have no profile, where do you live?/what equipment do you have.
If you want help provide the ingreiants to bake the cake.
Good LuckPAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
procoder also does a very good job at it (including express)
https://www.videohelp.com/forum/viewtopic.php?t=238542&highlight=
Solved my problem and it only cost me £5 -
Originally Posted by Squid_uk
I dont know much about a Component connection as i haven't used it personally yet.
8)
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 19:52 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 19:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 20:35
