hey guys i have a video fiel with ac3
and im converting it from xvid to dvd
ive converted it and all
havnt authored it et
but just wondering does tmpgenc encode it still keeping that 5.1 channel sound?
or is it now just a wav 2 channel
i saved the audio to a wave file using goldwave
im about to author it and realsie now that i need to buy the addon for ac3 for author
but still just at this point is the encoded files i have in ac3?
OK, this is how I do it (your method has killed the 5:1 and there aint much you can do other than starting again).
1)Open the avi (usualy an xvid with 5:1 AC3 audio) in VirtualDubMod
2)On the <Streams> tab select the audio (typically the only entry) and then press the <DEMUX> button>save the audio to a convenient place (takes about 2-3mins).
3)Now press <DISABLE> on the same (Streams) page as above (hashes will go thru the grey).
4)Now on the <VIDEO> tab select 'Direct Stream Copy' and now go to the FILE tab and select <Save As>...save to a convenient place.. (the new saved avi file will be audioless as I find that my encoder and frameserver baulk on xvids with AC3 audio..takes about 3mins).
5)Open the new avi (the audioless one) and frameserve to your encoder>using AVIsynth or VirtualDub (or VirtualDubMod)...but first..
FITCD has an excellent avi to DVD resize calculator in it (and includes 16:9 encoding flags and PAL), AND it will write your .avs (AVISynth script) for you ...frameserving has never been this easy....just remember to add this line to the script..... ConvertToYUY2().
If your using VD (or VDM) to frameserve select>VIDEO>FILTERS>ADD>RESIZE just set the <Expand and Letterbox> to the DVD resolution of your choice (either 720X480 or 720X576) and Resize (using Bicubic or Lancz) the avi to the resolution shown in <FITCD>. You dont even need the old calculator anymore..aint life great?
6) Open the frameserver file (.avs or .vdr) with your encoder and make a .m2v/.mpv file with you calculated bitrate settings....use BitrateCalc in Advanced mode for this.
7)Back to the AC3 file....first off run it thru AC3Fix (via AC3FIXGUI) to fix any problems (takes about 2-3mins).
8)Add the .m2v file in TDA and open the AC3 file along with it....!)...and ensure that little <REENCODE the audio....>box IS NOT ticked.
9)After chaptering etc write to the hard disk (you may not hear the audio if you preview!).
10)Play the resulting .ifo or a .vobs in a software DVD player to check the sound...now burn....
Job done...... AVI-AC3 to DVD-DD in 10 simple steps.
You will need the AC3 plugin for TDA.
Change video, keep audio without re-encode ? Problems with strange AC3.....
By Gwar in forum EditingReplies: 18Last Post: 27th Aug 2011, 08:19 -
how to encode aac 5.1 to ac3 on the fly in 64-bit windows 7
By MR 3 in forum AudioReplies: 3Last Post: 4th Apr 2010, 17:47 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Mkv to divx with ac3, ffMpegX will not encode anymore.
By biggyk in forum ffmpegX general discussionReplies: 15Last Post: 31st Jan 2009, 15:48 -
Encode an Xvid with AC3 in an MP4 container.
By Shibblet in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 08:28
