  1. i'm going to rip a dvd to divx,but there is a problem i've see a couple times.
    after ripping to the hard drive i'll play it with power dvd and where there are credits it switches languages.
    before i have stripped out the subtitles and audio with dvd decrypter and i was able to make a good divx rip,but i'm unable to this time.
    any suggestions?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Well you could use smartripper or another ripper. Then use virtualdubmpeg2 or your ususal method of dvd-divx (others include autogk, gordian knot, and simpledivx found in the TOOLS section on the left.
    Kevin
    --Does the actual dvd play normally??? Maybe theres a glitch in the source material--
  3. i was thinking about useing smartripper.i should have tried it before making a topic,but i was heading out the door.
    smartripper had the same audio and subtitles that dvd decrypter had that could be stripped except smartripper had a 'other',so whatever the 'other' is thats what needed to be gone.
    *pop*
