I finally got my 108 to burn a 4.7g at 7~8 mins. It would vary from 5x to 11x. The final time is about 8 mins. I heard there are some people who can burn at 16x using 8x media such as Ritek G05.
Has anyone able to burn at 16x using 8x media? By theory burning at 12x or 16x should give you a result of 8mins to 4mins. But I see that the speed vary thru out the burning process, it actually stops (0x) for a few seconds.
Please post your findings.
Originally Posted by tienquang2
These things clock burst speeds. Your 52x CD burner cannot make a full CD burn in 90 seconds. Your 16x DVD burner will never make a 4 minute disc. Never.Want my help? Ask here! (not via PM!)
Try the following DVD-R form Maxell, Media ID Code:MXL RG03, have successfully burnt at 16x with this 8x media.
You will never find a 4 minute 16x burner for one reason. Just about every drive available use ZCAV which means your burner will never run 16x through 100% of the burn due to the firmware write strategy.
The real answer lies in completely understanding the question! -
Originally Posted by twohawks
ive had a 5min 48second dvd,reportidly @ x16 burn.
dont know whether to believe it or not,but did notice 2 sections on the final disc that looked the same way that my old 8speed fuji discs would have when changing from 4-8speed-when the buffer emptys then starts speeding up(sorta darker rings)--not dye burns or flaws. -
8x media does 8 minutes on almost any 8x or higher drive, u need to burn at 16 x to go faster
Will media ever go beyond 16X?
By videobread in forum MediaReplies: 7Last Post: 22nd Aug 2008, 12:16 -
pioneer dvr106d burns but won't mount dvds on my mac g5
By muscmp in forum MacReplies: 6Last Post: 27th Jun 2008, 22:15 -
Phillips DVD+R, 16x, media code: CMC MAG. M01...These any good?
By i am x in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2008, 10:26 -
Starlogic 16x R+ Media
By joefromflorida in forum MediaReplies: 3Last Post: 31st Jan 2008, 21:17 -
CDROM that burns commercial media
By Krispy Kritter in forum MediaReplies: 6Last Post: 19th Dec 2007, 09:30
