Hi
I really hope somebody can help me here, I use these forums all the time but I have not yet come across a topic that deals with the error I am encounting.
Basically when I playback my DVD that I have authored every 5 mins or so the video speeds up and leaves the audio behind, then the sound gets jumpy and the vid freezes until the audio catches up again (lasts about 30secs). I have tried all sorts and not found a cure to this.
It only happens with 24fps files that I have re-encoded to 29fps.
The really strange thing is that I never used to have problems like this and using the same source that I used 1 month ago (that turned out fine) this time the video skips. I have even formatted my computer and started from scratch and used different DVD players to playback wih no luck.
I have tried re-encoding the video and all sorts, even using 3 different videos but still no luck.
Does anyone have any ideas or has come across this before? It odoes not happen when I make 25fps videos.
Shinobi
Shinobi XIII
"Silent Assassin" -
Does the Playback Speed problem occur on a PC or a DVD Player ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
What was the original source and what are you using to encode?
The original source was .avi - Xvid framerate of 23.97 fps with ac3 audio.
i used TMPGEnc to convert the file using 3:2 pulldown. I am using Ulead DVD Worshop 2 to author it. i have also tried Moviefactory 2 and it does exactly the same thing.
ThanksShinobi XIII
"Silent Assassin"
MPG jumps ahead
By Stokesy in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 1st Jan 2014, 10:54 -
Syncing DV footage with external audio recording - different speeds?
By mjl5007 in forum EditingReplies: 5Last Post: 20th Oct 2011, 06:19 -
Audio track speeds up going from AVI to DVD
By jenna1 in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2011, 16:22 -
I Give Up. Can't Burn AVCHD DVD Without Audio Being 4-5 Secs Ahead of Video
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 21st Oct 2010, 09:32 -
MPG still Jumps Ahead
By Stokesy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Mar 2010, 15:13
