I used dvddecyrter whatever, and I would like to make a vcd. Can someone please help me. Thank you.
This of this forum not as a school but more like a public library. If you would just spend a few minutes searching among the TONS of free information available you just might find the answer to your ??
....and just why in the hell would you want to make a VCD out of a perfectly good DVD?No DVD can withstand the power of DVDShrink along with AnyDVD! -
Because I dont have a dvd burner only a rom.
And the only thing I need to burn is 20 minutes long and I need to make a few copies. Its an educational thing.
Thank you for the help. -
You can try and do a MiniDVD, for those 20 min.
"Adopt, adapt and improve!" -
convert it to VCD using MainConcept frameserved through Virtual dub
hacking the Net using typewriter :D
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
NO AUDIO in DIVX files made by sub2divx
By etcohod in forum SubtitleReplies: 1Last Post: 16th Dec 2009, 23:44 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Would there be quality loss if 2 avi files of 700 mb made into one DVD
By meurglys0 in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2008, 21:57 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
