i am thinking about installing win xp sp2. i have many tools and such for video conversion and was wondering if anyone has installed this service pack. if after installing it did you have problems with your programs?
i am reading about this service pack and it does alot. before i install hp says i need to install alot of updates (10 for mine) or things will not work.
since microsoft is great for frelling up a good thing, i am wary to install this.
thanks,
nightscape
Results 1 to 11 of 11
nightscape
I had nothing but problems after it installed in an automatic update. Burner problems, Nero problems and printer problems. Took it off, no more problems. Unless it has something you really need don't give yourself the aggrevation.
I did a fresh install after slipstreaming the SP2 into a original XP (No sp's) so that I was installing as XP SP2. Nero 5.5 was no problem. So far on that machine Zero problems. Another customer's new machine Nero 6 (OEM) caused XP to complain so I nstalled SP1 and all the updates instead.
YMMV
Cheers -
thanks for the replys. i think i will wait a while till i install this service pack(prob not going to install). sp1 is working good for my conversion tools and i dont want the headache if it frells with nero 6.
have a good one all,
nightscapenightscape -
I wouldn't recommend it, until the bugs are all reported and fixed. Farscape rules, what is it now, 19 days until the miniseries? And the full 88 episode run starts on friday I think!since microsoft is great for frelling up a good thing, i am wary to install this.
i have installed sp2 and have not had any problems with it.. i had it installed for 2 weeks now
I am running problem free with Sp2 on both computers.
I have had sp2 installed since the final product came out. -
I've installed SP2 on both my home machine and office machine: Both are ASUS P4C800-Deluxe and both locked up - would post and start booting but hung during the Windows splash screen.
Solution was that they needed a motherboard bios update. Now all is well, everything seems to be working...
So, make sure all your bios's are current - it was a pain trying to get a boot disk. It'll be even a bigger pain if you only have one computer...
Best Codecs (WIN 7)?
By therock003 in forum Software PlayingReplies: 9Last Post: 10th Jan 2011, 07:39 -
Problems streamin mkv's between computers using Win Media Player
By xobituaryx in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jan 2011, 06:19 -
k-lite mega pack codecs 6.30 problems...
By sgbd in forum Software PlayingReplies: 10Last Post: 2nd Sep 2010, 05:46 -
Codecs and problems associated with them.
By rock.freak667 in forum Newbie / General discussionsReplies: 3Last Post: 14th Mar 2008, 13:30 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 13:54
