I have a movie on DVD+R. How do I put it on a DVD-R without re-coding and/or with no loss in quality?
Results 1 to 23 of 23
Copy the VIDEO_TS & AUDIO_TS folders, and their content, to your harddrive from the DVD+R. Then use any burning program, such as NERO, to burn these two folders, and their contents, to the DVD-R. Note that the AUDIO_TS folder will be empty.
So, I can just use "disc copy" even though the source is DVD+R and the destination is a DVD-R?
Yes
The files do not change.
The only difference if the media. -
bazooka wrote:
Wrong information. He does not select DISC COPY.Just use your burning program snd select disc copy.
Cannonball888 wrote:Use DVD-VIDEO in NERO to copy the VIDEO_TS file. You'll drag those files in that folder to the other COLUMN in NERO which has another VIDEO_TS FOLDER. Then you can burn it. If you don't understand check this guide on how to burn with NERO.So, I can just use "disc copy" even though the source is DVD+R and the destination is a DVD-R?
http://www.dvd-guides.com/content/view/40/59/ -
Same question here.Originally Posted by jimmalenkoWant my help? Ask here! (not via PM!)
i thought disc copy is for copying on the fly. so why would you use disc copy to copy from a hard drive? i just use dvd video from nero to burn the files off of the hard drive.
i read the question and if i'm not mistaken there are some who have problems copying disc to disc (on the fly copying) which is why i suggested using DVD VIDEO to burn.
Even simpler: Use DVDDecrypter and read to ISO. Then write ISO with the same app (DVDDecrypter)
/Mats -
Don't do on the fly. Use disc copy, and select the disc-to-drive-to-disc option. Still easy.
Why not on the fly? I always do on the fly and it works eveytime.
Imagination is More Important Than Knowledge -
I am using the same method as lordsmurf suggested.
I am currently copying a load of DVD-Rs to take to uni with me (want to keep the originals at home just in case) - I am using Nero to copy them. I do not do a "Quick Copy" which is on-the-fly - I deselect this so Nero makes an image then burns. I have had a couple of failed burns due to read errors, which is why I now do this. -
There is too big of a margin for error.Originally Posted by Severity
That is why on the fly is not encouraged. -
Never do disc to disc copy. What happens if there is a read error half way thru? Another nice coaster, that's what.
/Mats -
Hey folks, thanks for all the opinions, but I don't use Nero much for anything, because I have a slew of other programs. I just used RecordNow's disc copy function and burned it on the fly. Turned out perfectly.
It's hard to do unless you have BOTH a DVD burner and a DVD-ROM drive. Most people do not.Originally Posted by Severity
And even then, you've often got to have one on a separate bus of its own (meaning opposite IDE channels is not good enough, you have to put one one an ATA or RAID card to have 0% underruns).
It is far more abusive coaster-wise than drive to disc. I only do this for duplication work. If it's masters or personal stuff, I generally do disc-to-drive-to-disc.Want my help? Ask here! (not via PM!)
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 13:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
