i need help to know how to encoding a video to DVD+R???
Plz reply to me if u know how.
Results 1 to 17 of 17
i know how also -- anyone else ?
he's all fixed up and working -- but wore me out ..
Originally Posted by PnoyDragon06"Art is making something out of nothing and selling it." - Frank Zappa
Well i know how too. Pnoy what type of file & encoder do you have?!
RogThere are many ways to measure success. You just have to find your own yardstick. -
i need help to know how to encoding a video to DVD+R by using Easy CD & DVD CREATOR???
Have you read the guides? If not, please do so before posting back. If you have, please let us know the specifics of your problem so we can help.
/ Moderator Cobra -
i Know how too!!!
... this is fun
Pnoy,
if u want some help you're gonna have to provide a little more info than just what program you're using...
how bout u read the guides like the rest of u did so u can actually know what you're talking about....The distance between genius and insanity is measured only by success... -
Pnoy what type of file are you trying to get encoded? I downlaoded the guid to EZ CD & DVD Creator 6 and it was pretty much worthless. However, Most mpeg or avi files can be converted with AVIDemux a free video encoder. After you convert the file, you will need to author it before burning it to dvd. DVDAuthorGUI, DVDStyler & GUI for DVDAuthor are good free authoring programs. I think with either of them it will create a file that you can burn with Roxio.
Hope this helps
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
Encoding Video
By manicjonah in forum Newbie / General discussionsReplies: 8Last Post: 20th May 2011, 11:41 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 17:37 -
New to video encoding.
By pickledpacman in forum Video ConversionReplies: 1Last Post: 25th Mar 2009, 10:39 -
Best Video Encoding?
By mvtm in forum MacReplies: 3Last Post: 15th Mar 2009, 13:56
