Hello, most dvds let you choose if you want to see
the movie in widescreen format or fullscreen. Is there
a way that i can do the same when making a (dvdr). I
use TMPGEnc author, also what about zooming in and out
of the picture, just wondering.
Thanks..
You would have to rip both versions of the film, encode them so that they will fit on 1/2 a disk then author them so that you have a menu to choose which version you want. The problem is that you would only have 1/2 the space for each version, so you would have to drop the bitrate and resolution in half when you encode and the quality would suffer.
My 2 cents - Why do it anyway? Fullscreen is crap. You miss 1/3 of the image and the picture is completely butchered. Don't bother.
PS - Zooming is a function built into your DVD player so you don't need to do it with the movie."Art is making something out of nothing and selling it." - Frank Zappa
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD Video To DVDR
By tex78 in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 13:06 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
