Hi, I was wondering if that is possiable? Have several DVD rips with sloppy subs that I wanna remove.
Results 1 to 9 of 9
Hello,
Are they selectable subtitles??? You could just turn them off.
If not you could run them through dvd shrink, rerip them and deselect the subtitles entirely (you'll get an output the same size as the original rip but without the subtitles - take up a lot of space).
Or you could use virtualdubmpeg2 and convert them to divx using a filter that would cover up the subtitles.
Of course, the EASIEST way is to RERIP them without the subtitles! You do still own the originals right????????
hmm...well its a .avi file I downloaded from bittorrent so its not a official dvd copy, so the dvd shrink idea is out the window...however do tell me about the filters...how do they work and where can I download it?
Please tread carefully with this subject techjunkie. You're on thin ice here. You haven't violated any forum rules yet, but I suspect if you keep discussing this, you will
Capmaster, appreciate the warning however its not ripped from an official DVD. Its just a video file of a foreign drama series taped off the air then put on bt for fans to dl. The subs are grammerly-incorrect and I just want to re-sub it.
< grammerly-incorrect >
Wow! Those ARE sloppy subs!
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Hello,
In that case you can use virtualdub and delogo. It can be found by doing a net search for "delogo". You'll need to do a screen cap and highlight the subtitle. Then process it as you would any divx except it will remove the subtitles. (NOTE - it won't be perfect, it will remove them but leave a watery overmark). It's probably your best bet.
to drjtech - Grammatically Incorrect ..there happy now? Thanks for the help yoda, Ill try it
Removing Subs to reduce MKV size / other options?
By kmcc in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2011, 16:55 -
removing audio or subs with mkvtoolnix causes prob in media players
By lordhutt in forum Video ConversionReplies: 3Last Post: 21st Feb 2011, 19:05 -
Forced subs on HD-DVD rip
By jlchavis0844 in forum SubtitleReplies: 6Last Post: 19th May 2010, 07:40 -
How to rip DVD with subs always on
By paws in forum DVD RippingReplies: 2Last Post: 3rd Feb 2008, 13:18 -
Green subs appears on DVD but even when I rip it, on PC i'ts white!!!
By cemman in forum SubtitleReplies: 3Last Post: 21st Jun 2007, 14:57
