Hi,
Well I can now change the PIO to DMA, but now neither DVDDecrypter nor DVD_Lab will burn anything!
I use DVDDecrypter and all that happens is the bar which indicates the level of image burnt immediately runs to 100% then the cahce synchronises and I'm left with a useless disc.
DVD_Lab simply shuts down.
Anyone got any experience of this? Anyone got any ideas.
Bill
Results 31 to 37 of 37
Oh boy you are having a bad time....
About all i can suggest is a reinstall of the burning software and the hope it picks up the drive.Not bothered by small problems...
Spend a night alone with a mosquito -
Hi iooi,
Sorted! The dma enabled drive was working after I played with it. Turns out the disc image I was trying to burn was corrupt :-0 I'm getting upto 6x on 4x discs and 8.2x on 8x discs.
Now a happy bunny
Thanks to all for the help.
Bill -
Glad u sorted.
to do this you need the original pioneer kernel for the 108 as well as the firmware that you need. check out http://forum.rpc1.org/viewtopic.php?p=129268 for more info and help regarding this drive.Finally got my 108 to burn Ritek G05 in 8 mins. I want to experiment with fw 1.06 to burn Prodisc 4x at 8x, but don't know how to load 1.06 into my 108 b/c it is already got 1.14. Any idea on how to install 1.06 on 108?
as for the DMA thing... i had similar problems when i first got my drive - and the fix? I upgraded the drivers of my motherboard chipset to the latest drivers and things were fine from then on. (Before doing this i had no DMA mode for my optical drives at all!)
oO JOSH Oo -
I cant see the point in downgrading the firmware when it works OK on the newer one...
IF the new firmware wont burn something faster than it says then the old one sure wont....Not bothered by small problems...
First off remember that not only is burn speed dependant on firmware but you must also have software that supports the full burning speed of your burner otherwise you could 5,000,000x dvd media in your 5,000,000x dvd burner and it might nor burn over 2x
The real answer lies in completely understanding the question!
Vista 32 bit ... Disk full? but only 35GB files on a 108 GB c:\ partition.
By edDV in forum ComputerReplies: 6Last Post: 6th Jul 2010, 03:55 -
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 12:44 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
Sharp’s 108” LCD TV on sale for $185,000
By fairytale00 in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2008, 21:02 -
Pioneer 420H - Can't Write Data Error
By cie3 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 23rd May 2007, 23:51
