i must b going daft ....remind me guys , its a simple one to , 25 fps avi ac3 to dvd
extract the audio to uncomp wav ......done that with vdub
tmpgenc .....thats where i`m getting mixed up again , do i select the avi as vid source and the uncomp wav as audio , if so how do i know its gona fit on a dvd , i`m guilty of using the wizard normaly , without it i get all mixed up
or should i leave the audio alone for now convert the avi without sound and re-mux in tmpgenc author ac3
i hate loosing the plot which is what i have done tonight![]()
Hi gilbates,
I would use TMPGEnc to encode the video only (so your AVI is the video source) to DVD compliant MPEG2, and then mux in the AC3 during authoring (assuming you can extract the AC3 as AC3, as opposed to WAV).
I'm not sure, but you may even be able to have the AVI as the audio source during authoring and the authoring tool may just extract the AC3. try it - you've nothing to lose but a little time...
If you're not sure how to get the AC3 out of the AVI and want to stick with the WAV you've got, you can use that too during authoring or (as it's 25fps, I'm guessing you're in a PAL region) you could do WAV -> MP2 (I use ffmpeggui) and use MP2.
If you're not sure it'll fit - use the Videohelp Bitrate Calculator with the relevant bitrate for audio (WAV is 1536kbps, AC3 will be as per the original in the AVI (use AVICodec to see) and MP2 will be whatever you decide in ffmpeggui).
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
AC3 audio: 25 to 23.976 fps
By leghorn in forum AudioReplies: 7Last Post: 14th Mar 2012, 02:36 -
converting fps in ac3 files
By montevo in forum AudioReplies: 4Last Post: 8th Nov 2011, 16:29 -
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 07:37 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 09:35
