I'm converting some divx movies in tmpgenc. is there a utility which you can use which will tell you if a movie is 16:9 (ws) or regular? it would help when using the tmpgenc wizard.
thanks for any input
hes right.. or jsut do a right click/properties then look under advanced. if teh resolution is equal then its standard format.. but 9 times outa 10 divx are wide screen the format will be something like 6xx by 2xx or something.. the numbers very but you get the idea.. that example i just posted is wide as you can see.Originally Posted by jyn999
B4 i get flamed.. im not saying divx have to be wide its just that hte majority of them are because we all want the full film
not pan and scan
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2012, 00:11 -
find the name of this movie
By canadateck in forum Off topicReplies: 3Last Post: 22nd Jan 2010, 18:55 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37
