First off.. i did search and found a few topics on this but im posting this jsut to ask the direct question..
I have a few OGM files. If i open in vdubmod and direct stream copy to avi from what i read ill get a good avi file.. do i have to do the same thing for the audio? i know that ogm is only a container.. and my files have 3 streams.. one audio one video and one sub txt.. i dont want the text (subs) just the audio and video so i can play in my phillips 642. i did just rename the file and it played ok on computer but i just want to make sure i do it to proper way.. OGM is sorta new to me.
TIA everyone.
You can remux the Audio and Video to the AVI container, and expect it to play in your DVP-642 only if the file formats are compatible with both the AVI package, and your DVP-642.
If the audio stream is Vorbis, i'm afraid you'll have to convert it to MP3, or AC3. Seems like MP2 should work, but i havn't tried it.
Video stream must be one of the MPEG-4 codecs; DivX, XviD, etc., etc.
I havn't tried subtitles yet, but this machine is supposed to be able to play them. All you need is the latest firmware (that my unit came with).
(from the DVP-642 manual)Subtitle files with the following filename extension .sub, .srt, and .smi are supported. -
Thanks.Originally Posted by gastorgrab
I am aware of the subs.. i rip subs out of everything..
i dont want them. if i wanted to read i would buy the book hahahaahha.. J/K i know there is a use for them.
It wasn't the selling point for me either.Originally Posted by Heywould3
I'm still amazed that i can "dump" multimedia files on to a CD, or DVD in the most disorganized way, and most the files will play on my DVP-642.
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 11:19 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 00:56 -
OGM to AVI/DVD
By liveforit11 in forum Video ConversionReplies: 3Last Post: 20th Aug 2007, 21:20 -
Convert ogm to avi please?
By venus in forum Video ConversionReplies: 13Last Post: 11th Aug 2007, 17:15 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 14th May 2007, 23:33
