Source file is Photo-JPEG (have tried MJPEGb and MPEG-4 as well), 640x480 letterboxed (4:3). When I attempt to do an encode using ffmpegX to XVID (.avi) or MPEG-2 (.mpv) using the ffmpeg engine and cropping the letterboxes off to a 16:9 movie, the resulting video is only scaled to fit in a 16:9 frame. Thus, I am left with large black boxes on the left and right. The console log reports no errors and everything indeed seems fine with the encoding otherwise.
Major, you said this was an issue with dual processor systems previously (I am on a DP 1.25GHz G4), but that you didn't know where the problem was stemming from exactly in order to fix it. I have also tried encoding on a 433mhz G4 (upgraded iMac Rev B) and the video output was the same as from the DP G4, so I doubt this cropping issue has to do dual processors only. I am using the latest release with all of the latest libraries. Anyone have any suggestions/tips/work-a-rounds other than cropping with an app like Compressor or Cleaner first? Thanks for any help you can provide.
Email me to major4@mac.com a link to a small clip, your preset file, etc, so as I can reproduce your exact issue.
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
FFMPeg CLI : How to crop and pad?
By Bonie81 in forum Newbie / General discussionsReplies: 6Last Post: 26th Jun 2011, 07:31 -
to crop, or not to crop, that is the question...
By GrandPixel in forum Blu-ray RippingReplies: 2Last Post: 11th Nov 2010, 14:17 -
Handbrake: To Crop or Not To Crop
By meldavid in forum DVD RippingReplies: 1Last Post: 31st Aug 2009, 05:54 -
ffmpeg engine - how to add matting to 3:4 videos for 16:9 screens
By psychicmind in forum ffmpegX general discussionReplies: 1Last Post: 18th Nov 2007, 13:13
