  1. Hi,
    I have just got a hold of Gods and Generals. I want to take this disc (Half movie on one side, half on other) and shrink the two sides down, with menus and such two to seperate DVD 4.3GBs.
    What I want to know is, can I burn these two sides onto a dvd-9 and have a simple menu that says "load Side A" and "load Side B" Once selected, the disc plays the side, with menus and such.
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    keeping original working menu's when joining 2 DVD's is a bit complicated but it's not impossible. I have a couple of guides in my sig but they use DVDRemake PRO which is not free . Yours will be easier as both DVD's will probably have similar structures
    you may find it's simpler just using DVDShrink's reauthor mode and Titlewriter to insert a basic menu to go to either part of the movie but you will lose the original menus
    try a serach for 'merge' or 'join' in this forum and it will probably throw up another few similar threads with a few more suggestions
