From safi1
Looks like theres a RECALL
http://www.cyberhome.com/recorders_special_offer.asp
Results 1 to 12 of 12
Comment:
I've had NO lock up since upgrading the firmware several months ago -
I have a feeling that their RMA department is going to be running a lot of overtime.
Probably- the CH-DVR1530 has less editing features than the Cirrus logic(?) 1500Originally Posted by NightWing
http://www.cyberhome.com/DVD_Recorders_Comparison.asp -
Ok heres the deal, the 1530 is a little more solid, doesn't run hot. But you lost all editing features. So if your 1500, has given you no problem after firmware upgrade. Its a good idea to keep it if you need the editing features. Also the 1530 allows you to record up to 8 hours instead of 6. But who cares after 4 hours it looks crappy.
Any got a replacemnet fot he cyberhome 1500 to 1530
Does it run cooler and better? -
Has anyone here got one of the replacemnt model 1530's yet? I sent in my old one about three weeks ago and am still waiting.
I just got mine today. I can't tell if it has a fan or not but I do not see this machine having a problem with heat. It has over 300 slots on the top about a half inch wide and about 150 -200 one 3/4 inch slots on the bottom.Originally Posted by NightWing
I'm happy I got it but I don't know if I will hook it up as my Liteon is working fine. As a side note some others were concernd on another board about not having a recipt. I could not find mine either but sent it in anyway. Hopefully they have a better product with their second attempt at it. -
Anyone else tried the 1530? I'm curious about it Vs the 1500.... The feature set looks less. My main concern would be recorded video quality. Thw CH1500 seems to do a good job.
Roger
Need help finding replacement for Cyberhome player
By canofhumdingers in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Mar 2012, 20:15 -
Replacement program for MediaImpressions
By Scashaggy in forum EditingReplies: 0Last Post: 19th Jul 2010, 17:57 -
Looking for a replacement
By Peacedog in forum DVD & Blu-ray RecordersReplies: 7Last Post: 2nd May 2009, 18:13 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 08:28
