  1. Member Treebeard's Avatar
    Aug 2002
    okay using html form to submit information via email. Can I format the email that is sent so its not one big line of information, would like use html only if I can.
    thanks
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Since I'm HTML stupid I use Mozillas free composer (built into it) to make the text look how I want then copy just the text with the HTML formatting out of the code window and paste it in. Works great.
  3. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    Your ascii document would need carriage returns within the document. Or, if you opt for html document then
    will force a carriage return.
    Maybe you can expand a tad more on what you are trying to accomplish.
  4. Member Treebeard's Avatar
    Aug 2002
    i figured it out. what I wanted was a readable txt file when they submit the form. it was being sent to me via email and it was all ran together in 1 big sentance. i just inserted enctype="text/plain" and it seperated fields in the txt file for me.
    Thanks guys.
