Hello,
I have made a video-DVD with a menu, using Pinnacle Studio 9, and saved it on my harddisk.
I have made a picture-DVD with a menu, using Ulead DVD Pictureshow, and saved it on my harddisk.
The question is now: How do I merge these two and make a menu where I can select either one (i.e. video-part or picture-part) ? Is there a program that can do this?
I know that I have to rename som of the files, but I am not quite sure in which order. Can the program I am looking for do this for me?
Please HELP !!!![]()
Thank's :P
Marineflyver
joining dvds with menus is very complex:
dvdremake pro
https://www.videohelp.com/guides.php?guideid=646&howtoselect=6;57#646
i would instead make a new dvd with both the video and slideshow. -
If you have the original source data you can recreate the MPEG's and then drop both into your favorite authoring program. Done.
Most 'picture' programs allow you to burn to DVD and/or create a DVD compliant MPEG File. Generate this file and then create the Video MPEG you set to go.
Did the same thing a few weeks back.... worked great ... since I did not have the original DVD Video I had to extract the MPEG's from the VOB files.
Good luck -
I have used both those programs for a similar purpose.
I used TMPDVD Author which can take parts of many DVDs and put them together on one disc.... while you can usually keep the chapter marks, you will need to create new menus.
However, I believe the picture slideshow I created was somehow optimized as it took up very little space on the disc vs. its time. When I played it on the DVD player AFTER remastering it, the whole slideshow shot through with no delays between pictures (i.e. very fast). I don't know if the original program had some other way of pausing on a single frame (as opposed to playing it like a video) since it DID work correctly before I remastered it. -
Thank's for your kind answers, but there must be an easier way and a program that can do things for you.
The idea of just make a picture-mpeg is okay, but this also picture-DVD also contains video which is why I've made a menu on this DVD.
DVDReMakker Pro is maybee a way to do things, but when you get to the part of "Modyfi Commands 1...3" it gets real confusing. Another problem is the Host and Doner. Is Host one of the DVD's and the Doner the other, and you want to put the Doner's material onto the Host?
Please help med move on, creating a thierd menu where I can choose between the material the two merged DVD's?
Thank's
^JIR^ -
Host is just one of the DVD's and Donor is the other. The Host is normally the DVD that has the more complicated navigation and the Donor is the one that donates the parts to be added to the Host
the main menu file that allows you to choose either DVD is also there. You can replace this with any menu you want as you can create your own using DVDAuthor GUI
the commands part is confusing the first time or so but you will soon get the idea on what to look for and what to do. If you don't just ask as I wrote the guide and it only takes me a few minutes to see what needs to be done
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 18:45 -
Is it possible to add a DVD Menu to a AVI?
By Rayster in forum Newbie / General discussionsReplies: 9Last Post: 7th Aug 2010, 11:47 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 13:22 -
DVD Lab, Is it possible to add video to background on the menu
By frozenwind in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2007, 11:09
