  1. Hi,
    I'm using FairUse to make DVD's into Divx playable on a mpeg-4
    player. However I have a bunch of DVD's I have already ripped
    to a hard drive and FairUse only works with a physical DVD in the
    drive. I don't want to rip these movies over again.
    What is a good way of creating a virtual DVD from a hard drive
    folder (not iso or pdi, just vob's) so I can use FairUse on them?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could use virtualdubmpeg2 to turn vob into divx.
    Kevin
  3. Member Blazey's Avatar
    Dec 2003
    New York
    You could also turn the vob's into an ISO with Imgtools. Then mount the ISO with Daemon Tools and re-rip from there.
  4. Thanks Blazey,
    I was thinking of that myself but I did not want to have
    to wait while creating the iso. I was in hope there was
    a new way to mount the VIDEO_TS direct.
    Thanks also yoda313. While I use vdub,
    the batch utility of FairUse and the auto setings make
    life easier for multiple jobs.
