Hi,
I got NeoDVD so I could convert my PAL dvds to NTSC. Now part of it works, but on some episodes of the show I'm converting only the commentary track plays. I can't switch between tracks, so I guess only one was brought over. Is there a way to select the proper tracks I want?
I hadnt heard of this before. If you see my current post, I mention I am looking for a one click method for pal conversion
I was using IFOEDIT but had problems, try out I.ROBOT just released on DVDscr in PAL
I used IFOEDIT and the framing was all weird
so did you say that this works most of the time?? u mentioned it didnt work for a certain show, which one? did it work for most movies? -
This was the first time I've used it, so I don't know what to tell you. It did work, but it doesn't do me any good to have only the commentary track playing.
I'm currently just digitizing in my editing system. It's the long way to do it, but it should work better and I'll have more control. -
If you are just importing a VOB file off a DVD into NeoDVD the program will play back the first audio stream on the file which may or may not be the audio you want. I don't know how to work around that inside NeoDVD however there must be a utility out there that will allow one to rip the VOB file and strip off any audio not required then use the file in NeoDVD.
Issue with MkvToolNix - outputs incorrect or damaged video stream?
By tufffta in forum EditingReplies: 3Last Post: 27th Feb 2012, 04:14 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
Browsers freeze on live cam stream sites - flash issue?
By GlobetrotterSA in forum Video Streaming DownloadingReplies: 6Last Post: 6th Nov 2008, 03:35 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
