I'm having trouble getting a VCD to play on my Panasonic RV31 DVD Player. I converted the dat file on the VCD to MPEG with VCD Gear 3.05 and then tried to reburn the MPEG files using Nero's VCD creator, I got the following message from Nero "Invalid audio stream 32000hz 2 channel". After that failed I tried MPEG corrector and got the same error. Has anyone been able to successfully convert this type of dat file so that the VCDs are compatible with stand alone DVD players? The
VCD in question plays perfectly on my pc but who wants to watch a show on
their computer?????????
Any help would be greatly appreciated!!
Thanks!!
Milan
It is because the VCD standard requires 44100kHz audio sample rate. What is to do?
Demultiplex the MPEG and convert the audio file once again. Use the original bitrate but change the samplerate from 32000 to 44100kHz. Use the TMPG to do this, but use toolame and ssrc as external tools.
Multiplex afterwards. -
Why would U even need to convert a dat as it should already be mpeg compliant??? But as trueman said just demultiplex it or run it through Tmpeg as if U were converting a dvd using a set template within tmpeg
I tried demultiplexing with tmpgenc and I enabled SSRC in tmpgenc's enviorment settings. SSRC won't convert the audio to 44100khz, what do I need to do to convert the mp2 audio with SSRC? Any info would be greatly appreciated!
Thanks! -
Then save the a .wav file. You can use TMPG as well as VirtualDub to do this. Load the .mp2 as audio source, select file> output to file> WAV file. Save it as PCM uncompressed 44,1kHz. After that use this .wav file as audio source and start conversion to .mp2. I am sorry, what a hassle.
Problem trying to upload a stream....... I get video but no audio
By True Colors in forum Video Streaming DownloadingReplies: 0Last Post: 15th Oct 2011, 18:06 -
Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"
By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 12:30 -
Problem with one delayed audio stream
By ne0n in forum Newbie / General discussionsReplies: 0Last Post: 24th Jan 2011, 12:28 -
mencoder AVI: invalid audio stream ID: 128 - ignoring (nosound)
By dialallama in forum Video ConversionReplies: 3Last Post: 4th Mar 2009, 08:17 -
Sony Vegas audio stream problem
By PoT in forum Newbie / General discussionsReplies: 11Last Post: 10th Aug 2007, 13:35
