Y is it that all my audio is behind my video by 1ms? I manually change the settings in TMPGEnc to fix it but i want to know how to prevent it. Im using .vob files in TMPGEnc, deinterlacing them using Double, the audio is off unless i change it. What is causing this?
Do you mean 2-pass VBR? It could be various problems, one thing that you can do to correct the audio problem after you have rendered it without rerendering is import the mpeg into MPEG2Schnitt, where you can specify audio/video alignment and create a new mpeg without rendering. Another thing that you could do is download demux, found at Ted Rossin's site here:deinterlacing them using Double
http://www.geocities.com/ted_rossin/tools/Video/Video.html
Run your mpeg file through demux BEFORE rendering with tmpgenc. Demux will create a mp2 file, so you can just use that with the m2v rendered file in TMPGENC. Hope this helps. -
Originally Posted by jimmalenko
No shit.
Are you sure you don't mean 1 second?
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 08:53 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 08:51 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 01:59 -
After downmix audio video sync problem
By adarkenigma in forum Video ConversionReplies: 7Last Post: 17th Oct 2007, 10:10 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 05:27
