hello everyone i just converted my video tapes to dv i then convert them to dvd files using mainconcept mpeg converter,there is an annoying noise in the background of the tape i converted,is there anyway to reduce this noise in the background using mainconcept mpeg converter or any other software.thanks in advance
one problem solved can solve alot of problems
thanks alot for the tip
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 07:59 -
Building a new PC - This is annoying
By Des in forum ComputerReplies: 5Last Post: 9th Jul 2010, 16:54 -
Annoying noise in audio
By dexter30 in forum RestorationReplies: 5Last Post: 25th Feb 2010, 05:55 -
The Most annoying Celebrity
By Cirone in forum Off topicReplies: 22Last Post: 4th Feb 2008, 12:32 -
Annoying error i keep getting...
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 03:33
