I have a bunch of powerpoints that I would like to have on a VCD.
Obviously I would want the VCD to have a menu link to all of these, and to repeat back to the menu and not through the next powerpoint.
I have a few saved as individual images, transitions aren't used.
What software / steps would work for making a VCD with these?
I currently use TMPGEnc to encode and Nero Express to burn, but i'm willing to give other stuff a try.
Hi!
If you don't need the transitions in the PowerPoint pictures I suggest you save each picture as JPG with some grabber program, or with PrintScreen button i Windows.
Then use VCDEasy to convert the JPG to MPG stills. Now the rest is simple. Add your menu mpg stills and the created picture MPG stills and set the Interactivity for your VCD.
The result will be very good. However you can't have any transitions and music with this method.
// Znooky -
Record the Powerpoint presentation with Camtasia recorder and later convert it to VCD. The Resolution of VCD files are much smaller
- hope you are aware of it
. Right?
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 09:11 -
powerpoint conversion to VCD
By Kratz in forum Video ConversionReplies: 2Last Post: 19th Feb 2010, 14:16 -
Powerpoint to Video Help
By annieo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2009, 08:23 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:53
