Does anyone know why this is or how I can fix it? Its happened with a few movies I have tried to decode.
Results 1 to 9 of 9
I was wondering if I was the only one with this problem. I only encounter this problem when I encode a movie in 2 parts using the batch encode functionality of TMPGEnc, where the second part is approx. halfway the movie.
First part is encoded OK second part shows the message that you mention.
I have a workaround. Encode the movie using virtualdub as a frameserver.
Probably a bug is introduced in TMPGEnc in the latest version(s) -
TMPG's audio encoder is known to have problems to handle compressed audio. Uncompress the audio with VirtualDub to PCM uncompressed 48 or 44,1kHZ and everything will work fine.
Sorry Truman, I do not agree.
The first half of the movie does encode correctly. The second half doesn't, if I use batch encode.
If the whole movie is encoded at once, using batch encode or not (doesn't really matter if it is only 1 movie), there is no problem. No frameserving was used.
So, there is no problem with the audio of the movie. It must be TMPGEnc. -
I had the same problem, solution I used? raise your directshow to priority 1 under options-enviromental settings-vfapi plugin. I found 1(+) to be best since anything higher made encoding slower and divx playback wasnt working correctly (artifacting bad)
It only seems to happen with AVI files that have 48000KHz audio. All others do not have this problem.
Ya JasonD that did work how was your sound quality though afterwards? mine seems higher.
my sound seemed fine.. if you notice much difference, you can try to lower the quality to maybe 44000 instead of the 48000
I agree with Truman. It works for me all the time and it's a very easy solution.
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 01:16 -
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 14:15
