Hi. I'm using a Pioneer DV-350, and I'm playing back a DVD but I get no audio. The only two audio tracks on the disc are DTS tracks, so I think that's what the problem might be. I don't have the digital audio out hooked up to anything.. because I have nothing to hook it up to. Instead I just have the phono stereo out hooked up to the audio in on my midi system.
I was wondering if any of you guys knew anything about this? Should it be possible for me to get audio from a DTS audio track broadcast through the stereo out (though, obviously not in surround) so that I can hear it? Or is the simple fact that if the audio tracks are DTS, then I can't hear them unless I hook the digital audio out up to something?
Thanks for any help anyone can give me
You can only play DTS tracks through a reciever that has a DTS decoder. Is the dvd a commercial dvd? if it is, then it should have another track, either AC3 track or a stereo track. if your remote has an "audio" button on it, press it to change audio tracks.
Yes, DTS is the problem. Your player won't convert the audio into stereo like it would do for Dolby Digital.
He's a liar and a murderer, and I say that with all due respect. -
In order to hear the DTS you must ahve a decoder, they're built into surround sound systems, as well as some receivers. Your dvd player cannot decode(encode)? the dts soundtrack.... If you don't have surround sound just use the AC3 soundtracks. I found this out when I started out. dvd wouldn't have sound when through tv, turned on surround and it was fine. DTS doesn't matter to me so I still just use the AC3 files.
What We Do In Life, Echoes In Eternity....
Two audio tracks playing at the same time?
By churchie04 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Apr 2012, 23:34 -
Playing MKV with multiple audio tracks - does it load computer more?
By tufffta in forum Software PlayingReplies: 6Last Post: 4th Mar 2012, 18:44 -
I can't play back .m2ts files with DTS audio
By Quadcam in forum Blu-ray RippingReplies: 3Last Post: 24th Nov 2011, 17:31 -
Dual Audio Tracks Playing After K-Lite Codec Pack
By Boris_yo in forum Video Streaming DownloadingReplies: 9Last Post: 7th Jan 2011, 07:57 -
Suddenly no sound playing back audio (MP3) on MySpace
By phaedrus in forum AudioReplies: 2Last Post: 26th Jun 2009, 20:13
