I don't necessarily want to capture it...I want to copy it...bit by bit. I know there are tools out there to use it as a tape backup, and since everything is stored digitally, shouldn't I be able to simply "copy" the data from the tape to my HD , producing a file I could then convert to an .avi? I'm thinking this would negate the loss of quality inherent w/capturing.
Does this sound reasonable, or am I totally off here?
If you capture it, it IS a copy. There is no changing of the data in a straight DV capture.
I'm comparing it to something along these lines: http://dvbackup.sourceforge.net/
So capturing to a lossless format would produce the same results as copying it from the tape in digital form (bit by bit), then converting that to a lossless video format? -
DV is a compressed format. So saving it uncompressed would only waste space.
Hi Airjrdn,
Use something like WinDV or DVIO or VirtualDub to copy (transfer) from your DV cam to DV AVI.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
"Video: Stream attributes could not be determined" in Sony Vegas
By bloodshed in forum Newbie / General discussionsReplies: 41Last Post: 6th Nov 2012, 07:12 -
Sony Vegas Pro 11 Question: Video in Preview and Finished Render "Choppy"?
By MoreThanLuck in forum EditingReplies: 7Last Post: 31st Dec 2011, 21:17 -
sony Vpro 10 "video longer than sound" sony hdr-cx116e, part II
By cesarin in forum EditingReplies: 16Last Post: 11th Oct 2011, 07:20 -
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 22:09 -
Sony TRV 138 or TRV 350: do these camcorders have "pass through"?
By tadd5181 in forum Video ConversionReplies: 1Last Post: 24th Apr 2010, 19:38
