when trying to encode .m2v to, well, anything, with the ffmpeg engine and trying to both scale and crop (which i've done a million times before with mencoder), i get this error in the log before it encodes anything:
Vertical crop dimensions are outside the range of the original image.
Remember to crop first and scale second.
so i try setting my crop values first, then determining what resolution i'll be scaling down to, but i still get the same error. any suggestions?
Make sure your targeted size value is divisible by 16. For instance, this message will appear if you try to crop and make a movie the size of 640x360. Yes, its a 16:9 ratio, but it won't work. If you need to crop, then you would have to size it to 624x352, both numbers of which are divisible evenly by 16.
my final scaled image size was generated using the "auto" bitrate and image size calculator within ffmpegx, and is divisible by 16 in both dimensions: 688x288. my crop dimensions are also divisible by 16, at 720x368. the error persists. i don't get this error using mencoder, only with the ffmpeg engine, but i cannot encode this file with mencoder because i'm trying to retain 6-channel ac-3 audio, which mencoder always drops to 2-channel, regardless of my settings.
Are you entering the crop values in TBLR format required for ffmpeg (as opposed to WHXY mencoder format)?
There is even a little app doing the maths.
http://www.versiontracker.com/dyn/moreinfo/macosx/24666
FLV Extract Cropping Error
By TAS257 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2012, 21:55 -
virtualdub cropping/compression error?
By popoxDDD in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2011, 22:32 -
Error cropping picture for png images
By MKa2 in forum Video ConversionReplies: 2Last Post: 23rd Mar 2010, 11:12 -
ffmpeg "error cropping picture"
By eva01 in forum Video ConversionReplies: 1Last Post: 2nd May 2009, 18:42 -
ffmpeg engine - how to add matting to 3:4 videos for 16:9 screens
By psychicmind in forum ffmpegX general discussionReplies: 1Last Post: 18th Nov 2007, 14:13
