How many svcd movies can fit on 1 dvd? Does the program have some sort of counter or bar that shows how much of the disk is being used and how much more can fit on?
Thanks,
Suck it up princess !!!
I know when I goto burn, it tells me how much of the dvd is being used. I myself have put 3 svcd's on one dvd. Somtimes 4. Depends on the file size. Don't forget dvd is 4.7G.
I want to die in my sleep like my grandfather...not screaming and yelling like the passengers in his car. -
I never burn right to disc...I always check my VDEO_TS folder when svcd2dvd is complete...Then when svcd2dvd is complete I check the size of the VIDEO_TS folder. I keep the VIDEO_ TS folder to around 4.35 gigs
then never have to shrink it. I then play the VIDEO_TS folder in Power DVD Player to make sure all is OK. I check the menus and the sync to make sure I didn't screw anything up. Then I burn it with Nero Ultra.
I can fit 3 svcd movies on 1 DVD..I even made a webpage on how to do it.
Here's the page...if you need help and you are serious just email me my addy is on the site. I can hook you up with some of the software i am using to.
http//members.cox.net/aholic/svcd2dvd/homepage.htm -
Then try NeroBurnerOriginally Posted by aholic
Thanx for the advice Chrissy I will try it....NeroBurner
Chrissy your message board is the the best...
I got 2 valuable tools off here that I tried out and damn...
All I can say I wish I had been here a long time ago....
So many valuable tidbits that other peeps have already tried and errored...
Damn thanx for all your time and effort...and all your fellow posters.
I can't believe all I've learned in just 2 days..
Keep up the great work...This forum is is the best -
Thank Baldrick et al @videohelp.com. Their forums/site has been the best for some time....
Can you give me that addy again, or send me a message.
Sounds good, I'm really interested.
Thanks,Suck it up princess !!!
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
