I know, the title is cryptic.
I am ripping chapters from a factory DVD. I only want a few soundbites here and there. So I extract the audio track with 0SEx-0.0110a1 and then convert the .ac3 file to .aiff with mAC3dec. The process works just fine, but when I open the new .aiff in Sound Studio or any other sound editing tool, the sound is extremely quiet. I have to boost the volume of the audio file by almost 200% in order to get a file that I can actually hear.
Is there a reason why the audio track comes over so quiet?
Is there something else I should try during the extraction or conversion process?
I appreciate the help,
mrb
If you use the 5.1 channel surround sound AC3 track, you have to downmix it to stereo with mAC3dec, which can often yield very unbalanced sound. If you only have the 5.1 channel AC3, then you're stuck. If you have the 2 channel stereo AC3 track, try using that instead.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Why not just re-record the audio
using Audio Hijack Pro direct from
DVD Player, if all you wanted were
sound bites (no video)? You could then
go in and SELECTIVELY record the bites
you need, to a clean AIFF, ready to go without
editing....
seems like what you did was akin to killing a fly
with a sledgehammer....
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Recovering quiet audio
By ReedJohansson in forum AudioReplies: 6Last Post: 20th Mar 2012, 06:03 -
Ripping audio from DVD with chapter (Help)
By kenryuakuma in forum AudioReplies: 3Last Post: 30th Aug 2011, 11:14 -
VOB2MPG Quiet Audio
By gfinlay in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Apr 2010, 04:28 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57 -
Captured audio low/quiet/soft
By binister in forum AudioReplies: 1Last Post: 1st Dec 2008, 12:18
