I've got 3 Bond movies in VCD format that I want to put on one DVD and I plan on using TMPEG DVD Author to put them on the disc. Is there anything I need to do to the mpegs in order to make them usable by the program? I've read guides about having to convert the audio to 48000 or making sure the frame rate is 29.97, not the film standard of 23.97 but I'd like to get some feedback from users. Thanks.
try here, or look thru the guides section.
http://www.dvd-guides.com/content/view/57/59/ -
I found that guide but haven't seen any info on whether I need to do anything to the mpegs before importing them into the program. Does it convert the audio automatically? Does the framerate matter? That's what I'm trying to figure out. Thanks.
Audio will be automatically converted to 48 khz as long as the framerate is 29.97,if its 23.976 then the video has to be re-encoded.
Only with mpeg2 when played back by a dvd player,mpg1 has to be either 29.97 for ntsc(no 3:2 pulldown) or 25fps pal.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 06:30 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 16:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 00:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31
