I am using a AverMedia PCI Capture card and Virtual VCR using settings 352x240 29.970 and 320x240 25.00 with no compression..
when I use the default setting the audio delays seconds before the video and when I use 29.970 the video delays from the audio several seconds another issue is that avi files are very large, is there a way to compress this files in order to reduce the hard drive space... ? if yes is there a quality change if compressing the avi file... I have to use Virtual VCR without the video preview in order to get a better and non skip video.. if I used video preview while capturing I get a fast forward video.
Thanks.
ps. if you know any other software to capture video better than this one please let me know.
Results 1 to 11 of 11
this may not be much help but i use vitualvcr and find it the best capture software for my winfast vc100 card.i captured at 720x480 and used the huffyuv 2.2.0 codec with no frame drops.i also used onboard sound.i converted to mpeg2 using tmpgenc keeping 192k/s for audio.the burnt results to dvd are practically the same as the satellite i captured from.try iuvcr trial version and see if you think that would be more suitable for your card.
Have you tried the settings I suggested at the end of your last post related to this topic? They may help.
https://www.videohelp.com/forum/viewtopic.php?t=237377&highlight= -
Yes, I did..... they did help. now what I am having a little problem is that the video afer 10 min the audio gest behind seconds and also when I try to improve the quality I get lines when the video moves... it looks clear but when the camera moves I get lines. is this when the filter comes in? what filter do I have to use and how? I am using virtual VCR.
Thanks.
Pirata
If you are getting lines when you have motion, that's probably just interlacing. It won't be a problem when you play it on a tv. As for your audio problem, if you have things set the way I suggested and it doesn't work, try playing around with the different audio settings on that same tab. Perhaps another setting will get rid of your problem, but I wouldn't know for sure because the setting that dynamically resamples the audio works for me to keep things in sync.
Sorry I can't be of more help. -
Actually, I just saw something in another thread that may help:
Try reading this page of the thread:Originally Posted by sacajaweeda
https://www.videohelp.com/forum/viewtopic.php?t=238098&start=30 -
you might just wanna try to switch to virtualdub. virtual vcr is a great program but i know i had alot better luck capturing with dub when i was using my cheap mpeg tuner card
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Have you set resample audio-resample audio dynamically?Its under av sync in virtualvcr,i can capture for hours with no sync problems with that setting.
I used VirtualVCR for a short while when I moved over to XP from 98SE. Although I managed to do long captures at DVD settings and keep both video and audio in sync, I noticed that when the captured avi was encoded to mpeg with TMPGEnc, it threw everything badly out of sync. There was nothing I could think of to re-sync the file and I was about to buy a drive caddy and format a Win98SE partition and go back to my fantastic AVI_IO capture program, when I saw a nice Hauppauge WinTV PVR-150MCE for a mere £50 ($94 USA?)...
Ego
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 15:53 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
Please help: Virtual VCR not detecting Audio Device
By cnfcnf in forum Capturing and VCRReplies: 6Last Post: 30th Jan 2011, 13:17 -
Virtual VCR Trouble - Error 80070003: Cannot start graph
By MJDore in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2009, 20:12 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
