I downloaded the latest version of oSEx application and tried to open it but everytime I double click the icon it will give me an error message stating that there was an error and that other applications were not affected. I even downloaded an older version but had the same problem. For those who were successful in using this program, can you tell me what version you are using? I have a 10.2.8os DDM G4 mac.
Results 1 to 9 of 9
You might try upgrading to the latest version of Stuffit Expander and uncompressing its archive again. The symptoms you describe are identical to ones caused by the use of old versions of Stuffit Expander.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Thanks WiseWeasel. I drag it to my stuffit application since I know I have the latest version and the osex works. Maybe I have an older stuffit lying around somewhere I guess.
Yeah, that's happened to me before. Try doing a search for 'expander' and delete any copies of Stuffit Expander before version 8.0.2.
Stuffit Expander 9.0 is out
http://www.stuffit.com/mac/expander/index.html -
Why do you want to use OSEx, by the way? It's been a dead project for a couple years now (along with DVDBackup), so it's bound to stop working eventually. I would suggest using YadeX or MacTheRipper, which are both in active development.
By the way, this forum automatically adds links to the tools section for apps that have been registered in the tool database here. OSEx is one of those registered tools. You can disable that by checking the 'Disable automatic tool link' option when you post your message.I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
No program will open at all.
By Akhet in forum ComputerReplies: 26Last Post: 14th Dec 2011, 18:32 -
Question about disappearing program in the "Open with" dialogue
By jimdagys in forum ComputerReplies: 2Last Post: 4th Dec 2009, 04:35 -
open source program for converting .avi and/or mpeg-2 to .f4v
By lapchumic in forum Video ConversionReplies: 2Last Post: 9th Jun 2008, 13:10 -
I have a .DAT file and don't know what program I need to open it
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 16:42 -
What program to open up a .tv file?
By Gandolff in forum DVB / IPTVReplies: 0Last Post: 12th Sep 2007, 13:28
