Maybe someone can shed some light on this for me. I have a Divx movie and when I try to convert it to DVD I get all the audio but about 3 mins through the movie the Video becomes pixelated & then freezes, yet the audio continues to play. I have tried converting with TMPGEnc Plus 2.5 & TMPGEnc Plus 3.0 Xpress. I have also tried with CyberLink's Disc Wizard & same result. I have also used virtual dub to decompress the audio and get a seperate wav file. When I watch the Divx on my PC or burn the divx to a DVD+R/RW & play it on my Philips DVP642 player the movie plays fine all the way through. Any ideas as to why this does this after the conversion? Or maybe a different method is needed. Someone please let me know. Here is a screenshot of the Divx's file info that VirtualDub gives me. Thanks in advance.
Results 1 to 9 of 9
Father knows best.
Corrupt video
If you have a copy before you used tmpgenc on it.
Reencode using virtualdub.
If you do not have another copy, then download again. -
OK which methods of recoding should i follow using Virtual Dub? I also was curious if it would help If i were to run the divx file through Dr. Divx?
Father knows best. -
Well, IMO, the DIVX video has to be flawless. My DVIX video's are read from DVD. I can now convert them with WinAVI Video Converter to DVD. I might be wrong on this, but once u Author a DIVX/XVID file, its done. Can't re-do the file FROM DIVX.
if you can play it back why bother to author as a DVD?
I want to be able to play this back on my Standalone player. I think i may have to dload again. Can problems such as these occurr during dload process. If so... How do i prevent it?
It just might be ther person who your downloading from. They prolly don't know what their doing. Find a different file to dl from.
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 15:35 -
Encoding a Video-Divx got Size Problem...
By PzSniper in forum Video ConversionReplies: 3Last Post: 17th Sep 2009, 17:59 -
Problem of jerking in video while Converting DV to DivX / Xvid / DVD
By ckbasak in forum Video ConversionReplies: 7Last Post: 30th Dec 2008, 08:23 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
Video Problem with Divx/Xvid files on Media Player
By Vid-Kid in forum Media Center PC / MediaCentersReplies: 2Last Post: 16th Dec 2007, 22:09
