Take it easy. I think he was referring to his experience or training in the field. He wasn't trying to pick you up :POriginally Posted by DereX888
Closed Thread
Results 61 to 90 of 90
bazooka is correct, and I am not going to tell the rest of you how to do it.
It is not that difficult but you script kiddies cannt do it. It requires real programing skills, a knowledge of Windows files headers and footers and understanding of exactly what an executable piece of code is. Take it from a programing pro, a virus can ride inside anything that you can download. Even encrypted and embedded in a jpeg file. There are many texts on this subject and if you really want to know then do the research.
Dammmmmmmmn ...... All the good threads happen when I'm asleep
I've read through the entire thread and haven't been able to stop shaking my head.
It's a ******* internet forum, people.
There is absolutely no need for all this "you calling me a liar" bullshit. I mean, what are you going to do about it if someone IS lying ? As the latest vulneribility with JPEGs shows, it is conceivable to me that any file format could carry virus code. Whether windows will fall over because of it is another matter that I don't think any of us really knows, and I'm certainly not prepared to try it out for the benefit of everyone here
Something to think about - if you take virus.vbs and rename it virus.mpg, is it a vbs or a mpg file and why ?If in doubt, Google it.
I havent heard of MP3 being able to carry viruses, but you can embed a virus/script into WMV and WMA, check out the script section of Windows media encoder SDK. These scripts will execute through WMP. I have come across WMV that opens dialog boxes and then send you to their website.
Maybe we can come to an agreement here...
#1--A "virus" is a naughty bit of programming code with can do mischief, as well as replicate itself. I think we all understand that.
#2--Being code, it has to be run at some point, otherwise it can't do anything. It's still a virus, but it's not a problem yet. I think we all can agree on that.
#3--ANYTHING can have that code in it, or attached to it, or BE it. However, as per #2, unless that code is run--either by a program/player which recognizes it as code to be run, or script/macro to be run, or it runs by itself, it sits there dormant and innocuous.
#4--If mp3's and jpg's (and I know wmv's do) have metadata that can call URL's, this is a hole/window for malicious code to reside and execute...BUT ONLY if it gets executed.
#5--In the case of the above, this can only happen when "played" on a player/program that recognizes and acts upon the existence of such metadata.
#6--I think we all can agree that a "myfavsong.mp3.vbs" is really a vbs masquerading as an mp3 to those unfortunates who have hidden their file extentions. As a vbs, it can be a vbs virus like so many others. (Same goes for .exe, etc...)
How to avoid these kinds of virii:
1. Show all file extensions
2. Never directly open a file from the web, download and then AV scan 1st.
3. Set IE to not run ActiveX without asking 1st.
4. Set OutlookExpress to read everything as plain text (no HTML...you can still view the HTML if you save & scan attachments)--this has saved my butt 100's of times.
5. Play multimedia files (jpgs, gifs, mpgs, avi's, mov's, wmv's, etc) ONLY in players that just show the payload, not futz with any metadata (or certainly not without asking 1st).
6. Only open scriptable stuff when physically OFFLINE from the web. and include a firewall like ZoneAlarm.
7. Routinely AV scan EVERYTHING on your computer, not just executables.
Anymore questions?/Arguements?
I'm sure this'll date me, but this kinda reminds me of that old "Backwards Satanic Message" BS from the late '60s/early '70s.
Similarly, as long as one didn't actually rewire their Phonograph players to play backwards, you'd never hear anything of the sort. (I did, cuz I wanted to see what all the fuss was about. Don't waste your time)
We need to stop using phono players that have those extra "Backwards"-capable switches.
Originally Posted by FOO
they do - see https://www.videohelp.com/forum/viewtopic.php?p=1054913#1054913
winamp and wmp both read these tags - so do other apps ..
on the winamp forum -they explain how to construct a tag so playing file will either open a web page or link (which can record an ip or be designed to do whatever web pages can do)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
"Because they cannot contain viruses or other malicious code, files in the MP3 format are generally trusted by Internet users, who freely swap such files with strangers over services such as Morpheus, Grokster and Kazaa. "Originally Posted by John2001
EDIT: i stand corrected. again thanks for the post John.. thats the info i was looking for,
Perhaps you should have before posting!Originally Posted by Heywould3
from the 2nd link.
and:It is possible to modify an existing mp3 file in such a way that it can
carries a virus. The virus is activated when the mp3 file is played in
Winamp
So, a version of winamp contained a flaw that could lead to a buffer overflow condition. As you are well aware, this is a common type of flaw and often use to spread malicous code. So it looks to me as if an Mp3 containing a carefully crafted URL to exploit this flaw, and also containing some malicous code, is/was a possibility. Note, this is a virus within an otherwise valid, and playable mp3 file, not simply a URL to download a virus from.The buffer overflow condition occours when the url
string intended to be sent to the minibrowser is created. That means the
buffer overflow occours before any actual internet connection to
info.winamp.com is beeing made.
As there is now a verified windows exploit using nothing more 'executable' than a jpg picture file, I don't think it safe to assume that any particular file type is safe.
EDIT: BTW, I am not trying to claim that such a thing as a virus carried by an mp3 or video file has ever existed, at least not 'in the wild', just pointing out the theoretical possibilities.
Thank you Bugster.Originally Posted by bugster
Yes, It looks like this is partialy true.. (Winamp Bug) and again.. i was just looking for facts.. it is a fairly new devlopement therefore people stating that it was not possible WERE at one point correct.. the people stating you can are currently right..
I was just looking for verifiable proof which we now have..
To the original poster.. if you follow the last 3 links you will see that it is in fact possible in some cases to have a virus run in an mp3 in some media players.
is nothing sacred? sad day for some P2P users. oh well.. if you dont have a good AV and you allow activex you are bound to get into trouble anyway
It looks like this topic can finaly end.
Like someone saying July 19, 1969 that man could never land on the moon. And are equally right saying that you can, July 20, 1969?Originally Posted by Heywould3
/Mats
An mp3 could have a virus in the same way that a jpeg could have a virus - the mp3 could cause a buffer overflow in a particular player (heres the rub) and then cause the virus payload to be loaded into the overflowed stack frame. This is entirely possible. But AFAIK there is no such MP3 virus in the lab or the wild.
As for mp3s causing a player to open a URL - you do firewall both incoming and outgoing traffic, don't you???!?!?
It is *VITALLY* important to make sure that you know what information is being sent from PCs behind your firewall out to the internet. Most of the hardware firewalls automatically allow outgoing traffic without permission. Do try and stop this. It will take some work to create a manageable and workable system but it is possible (hint: authenticating proxies on bastion hosts...)
Originally Posted by mats.hogberg
there are people today that still say we never have :P we dont want to get into that now do we
well i never said you couldnt make one.. i just said that up to the point i was refering to there wasnt.. not that it couldnt happen.. so thats apples and oranges..
I have many times stated that all i wanted was verifyable proof.. not that it couldnt happen..
problem with topics like these are that when they get too long people will post on a certin post and not read the rest.. people are now starting to post statements that have alreadybeen gone over or discounted.
im somewhat guilty of this too.. but we dont need to go over the jpg or mp3 overflow bug again.
wasnt this started on an AVI or mpeg file ? in the first place?
I would still say "Freeze" sounds like an exploit not even really a trojan, and no where near being a virus.
None of the "possibilities" are viruses or worms, if anything they are exploits.
I still say there is NO MP3, MPEG etc. virii that infects and spreads it's self to other files.
NONE of the links you posted were talking about a Virus or Worm. They were talking about exploits.
A Virus or Worm spreads it's self to other files and infects them, it replicates.
Your MP3 does 1 thing, that's a trojan...but from what I see it isn't even that.
For a security expert who doesn't know the differnce between virii & trojans, worms etc. I would look for a new line of work.
How do I remove/repair AVI video file virus?
By paulywalnuts in forum Newbie / General discussionsReplies: 6Last Post: 7th Feb 2011, 21:40 -
Question about virus so terrible that Ghost restore did not kill the virus
By jimdagys in forum ComputerReplies: 24Last Post: 27th Apr 2010, 11:58 -
VIRUS,VIRUS, Getting blocked accessing antivirus sites
By G)-(OST in forum ComputerReplies: 11Last Post: 10th Apr 2009, 03:40 -
Virus in video
By zoobie in forum Newbie / General discussionsReplies: 11Last Post: 10th Feb 2008, 01:54 -
virus internet suites and video capture advice sought.
By DBenz in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2007, 21:19
