My computer just shut itself off. When I tried to restart, the monitor doesn't turn on and my motherboard just says failed cpu test. Any ideas?
Dark booty out.
Sounds like overheating.
If the cpu is fried, you will need a new one.
If the cpu is not fried, put some thermal paste on the cpu and get a better heat sink fan.
Also check to see if the heat sink fan is still seated properly. -
The computer has been running fine for a year. Maybe a bump could nock the fan or heatsink loose. The computer was running when it quite. I was loading anti virus software.
Dark booty out. -
Well the antivirus should have not caused a cpu failure.
I would open the case and see if the heatsink is still seated properly. -
Thanks for the help. I'll have to do that when I get off work.
Dark booty out.
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 17:01 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
