HI,
I used Virtualdub to separate audio from video and therefore Mainconcept MPEG encoder to convert a divx to MPEG2. When I import the audio file during the authoring with TMPGencDVDauthor, I receive the following message:
Illegal audio format.
For a standard DVD you can only use the following audio formats:
Dolby Digital (AC-3), MPEG-1 Audio Layer-2, or Linear PCM.
I tried also with DVDlab and I receive the same error message ( the format must be 48 Khz). A friend of mine suggested me to use a software to convert ( such as GoldenWave) and another one told me that also VirtualDub can convert the.wav file to the optimal format but how?????
Thanks for your help
What format is the audio you extracted from the AVI? (sounds like 44.1khz MP3). Besweet (freeware) will convert the audio to 48khz PCM or MP2. Both will be acceptable to DVD-Lab and Tmpgenc DVD author.
what kind of option should I use ac3 or other if I want to create a dvd (PAL system) with TMPGenc DVDauthor?
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
