im downloading some movies, dvd rips,their approx 700mb avi files.
i want to,if possible, after i convert, fit an entire movie to a 80min 700mb cd-r..im sure id lose quality, but not sure which guide to follow.
can i convert a 700mb avi file to a ready to burn vcd file? and fit it on 1 cd-r?
(not good with words or explainin things) lol
i wanna make a VCD but have the entire movie fit on 1 cd-r.
hmmm u maybe right, i just did a small test with that guide, and the results look horrible along with the sound..im prob better off just burning the entire movie as a data cd (on 1cd) and just play movies on the PC.
You can try my TMPGenc template which I use all the time (you may have to change it from PAL to NTSC if you live in the states) >
http://www.angelfire.com/jazz/deckard/deckard.mcf
Pop it in the 'Template' folder
Use it via the wizard. -
Sorry, You may have to Right-click/Save As. Direct linking not allowed on Angelfire.
Which is Best Resolution for 1CD DVD-Rips
By mani4frenz in forum DVD RippingReplies: 11Last Post: 28th May 2009, 09:53 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
