I have a very large AVI file that I am trying to burn to DVD, however when I try to burn it says it is to large for a 4.7GB disk. How can I size it down ( without losing quality) to fit a 4.7 GB disk???? I know of dvd shrink, however I believe that is just shrinking a DVD format movie......
Please help ...... Thanks
You might try opening it in Virtualdub, then frameserve to TMPGENC. In TMPGENC you can choose the bitrate and other things to make it fit a DVD.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
It depends on if you want to keep in AVI format, or re-encode it to MPEG format.
If you wish to keep it in AVI format, use virtualdub to re-encode to to a lower bitrate. You may have to reduce the frame size in order to retain decent levels of quality, but only you can decide if this is necessary.
If you wish to re-encode to MPEG, try the guide here.If in doubt, Google it.
i have a question. DVD to a single avi/mpg.
By adan_4u in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2010, 00:22 -
AVI to DVD Question
By Cyberian75 in forum Video ConversionReplies: 2Last Post: 8th Jul 2010, 20:06 -
AVI to DVD audio/video question
By Iconoclast_211 in forum Newbie / General discussionsReplies: 3Last Post: 25th Mar 2009, 13:00 -
AVI ---> DVD question
By arcticmoonshadow in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 22:40 -
AVI to DVD question
By cajmere in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:29
