Hi, I installed tmpgenc on a friend computer and when I raise the directshow filter priority in environmental settings (to bring it to top or even modified it to priority 3 or 4) and try to open a film to convert, tmpgenc crash with an error message: tmpgenc.exe generated an error and will be closed by windows. If I dont raise the directshow priority all work fine but I lose sound on the converted video (I have sound at first then in middle of film sound disapear), and most of tmpgenc problem are solved by raising the directshow priority, I tried with 3 different movie and always crash at opening of the file if i raise the directshow priority, I can play both file correctly with mediaplayer classic, and no problem, the sound is good all along. Any suggestion on how to fix this would be appreciated. Thanks.
sounds like tmpgenc is having problems with the audio portion of the file. you may want to convert the video and audio separately.
make sure the audio is not vbr. tmpgenc does not handle vbr very well.
Directshow filter for the Animation codec
By roflwaffle in forum Video ConversionReplies: 8Last Post: 12th Oct 2010, 16:09 -
Directshow filter for decoding MPEG-2 TS
By roflwaffle in forum Video ConversionReplies: 5Last Post: 17th Aug 2010, 08:55 -
Directshow Source Filter Issue
By kakskulkarni in forum ProgrammingReplies: 0Last Post: 30th Jun 2010, 19:25 -
DirectShow Filter Problems
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 2nd Oct 2008, 23:12 -
Directshow filter being used...
By fabvideohelp in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2007, 13:27
