  1. Hi. As the topic states im using a Sony 510a.
    Been using this drive for over a year and never had any problems. However, my dad purchased 200 dvds so we wouldnt have to buy more for a good while. I had been using Bulkpaq orange dvd-r's and everything was fine so my dad decided to get the majority of the disks of that brand
    Now whever i try to burn dvd's the writer throws it out after around 3 mins. When i compared the disks to mine the newer ones were a slightly darker orange but both have "generation 4" on them and also "4 speed".
    So I gave 2 disks to 2 of my friends and asked them to try them and both worked fine so I know that it can't be anything to do with the disks.
    I tried upgrading the firmware thinking that was the problem but no luck with that either.
    If any additional information is needed then ask away. Cheers.
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    When the writer ejects the disc after 3 mins, does it give you an error message? If so, what is it?
    SLICK RICK....
    Nobody likes a bunch of yackity-yack.
  3. Hope this tells everything otherwise ill give more info.
    http://www.jm009a8334.pwp.blueyonder.co.uk/Log.txt
