  1. i m trying to convert rmvb file to dvd file by first ripping off the audio using eo video and then putting it through tmpgenc to convert to a DVD format.
    the problem is that when i rip the audio from the rmvb file the audio that i play is in two different languages and it is over lapping one another. Is it possible just to convert one of the audio file? if so how do i do this? or provide me an alternative solution ?
    thanks
  2. I had this problem too. Choose the bilingual choice instead of the stereo choice and that should work.
  3. hi
    thanks for the reply.
    Do i do this in the eo video or in tmpgenc? because i cant find it would you mind telling me where to go?
    thanks
  4. You can choose this option when you burn your files with TMPgenc DVD Author. When you choose Add file another window pops up and you can choose the option there. Hope this helps!
