I have been given a pal dv video tape to capture and edit.The problem is I
have a NTSC sony trv33 camcorder. I can view the tape on the lcd sreen but can't capture it. I have tried firewire and composite out to my AWI card nothing works the best I get is the picture with green and red lines through it when i try through the AWI.. I may be able to get the pal dv camcorder and try capturing that way , will this work the easiet? or is there a way I can do it with my camcorder??
I think that's a only way it would work. You need a PAL Camcorder or VCR for it to playback into the AIW card. All you do is set your input to PAL instead of NTSC.
I asked about converting a tape the other day and that's what I was told because I picked up my AIW 9600XT
PAL non converting VCR's run about $100. You might want to check locally to see if anybody rents them out.Project Digital: Eliminate All Physical Media is finally underway!
PAL mini DV tape in NTSC camera
By Berghof in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2025, 08:02 -
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 11:54 -
NSTC to PAL, on Mindv Tape
By poacher in forum Video ConversionReplies: 6Last Post: 29th Dec 2009, 14:56 -
NTSC vs PAL tape help
By atothedb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Oct 2007, 20:38 -
capturing PAL Beta tape
By sickyd in forum Capturing and VCRReplies: 5Last Post: 1st Aug 2007, 22:14
